FZ1inTX
Adminstrator
I caressed her tank on a couple of pass-bys to get tools out of the garage... She forgave me for not riding her today.
Nicely done Tony. Do you have a pic of the clearance when the adapter is plugged in? My Garmin adapter seems to be rather tall so I am considering a mount where you put that rocker switch.
You mean like this picture?
Yes and no. One from the side looking in with the bars over the adapter. I think my adapter is bigger than yours. :ban:
What kind of hand did you wind up with????
Got around to finishing the install of the marine grade power outlet and Garmin GPS handle bar mount. The outlet fits perfectly on the left side panel. Got everything wired with a 5A fuse. Over the Winter I'll probably take the time to solder all the connections, but for now it will do. I opted not to get a weatherproof mount as I really don't have a need for it. I am using the factory Garmin mount so it's very easy to remove the GPS, yet it holds it in place very securely.
Ok, if I remember tomorrow I will take such a picture for you
It looks great Tony. I didn't realize how much "flatter" your GenII inserts were compared to mine. You probably could have used the plate that was provided in the kit? It looks really good. Dont forget to bring a quality ZipLock bag with you for the GPS just in case.
Looks great Tony. If I ever get around to adding it perhaps you could supervise me. I was just thinking this morning as I was lost somewhere north of Bound Brook that I could sure use a GPS. I was out for about 3 hours and decided I had enough of the heat and came home.
No, there was no need for that plate at all. Without the plate it looks better anyway. Yes, I'll bring the ziplock bag just in case, but if it's raining chances are I wont be riding.
What does that mean? If it rains you'll be taking the car?, cause Wednesday looks like it's in the crapper so far according to the W-Man. Then again, what the hell do they know!
Ok I think these two cover what you were looking for Eric
