bikerwayne
What type of lube did you use?
Thanks Tony! I will give this a shot, maybe tonight! The answer to my message to them was this:
I think it will work just fine. I will suggest to them that they zip-tie and not insert their copper collar for future sales thus making it simple for the buyer.
Thanks!!
So how did you go? Did you manage to press out the copper bushing?
I just recieved mine in the mail and the bushing is in place but held there with a zip tie. It isn't a press fit, it would just fall out without the zip tie. Since I can't get a reply on what lube removed the anodizing what lube are you other guys using with good results, white lithium grease???
One issue I have noticed (and this is a personal thing) is that the brake lever for me is not really optimal for two-finger braking. It's fine but my first finger has to really stretch to reach to reach the lever at first.
Dustin, have your friend but his sv lever part numbers into a reverse parts lookup (ron ayers parts site has one). He should be able to find other bikes that use the same levers and may be able to find adjustable ones that will fit his bike.
you cheap skates! why don't you just buy some real pazzos! j/k my FDB levers are in the mail right now! these reviews have been very informative, thanks a lot. black standard length with red adjusters, $54 shipped. can't beat it. F you pazzo!
