NJFZ1
Moderator
FYI...Today I put a 47 tooth sprocket on my stock 2006 FZ1. The stock chain wasn't even close to being able to fit even with the wheel pushed full forward. I put the stock sprocket back on and put a 16 tooth on the front. I have no doubt that the stock chain still won't fit if I try the 47T again. I will buy another chain (and chain tool).
Do you think a 130 link chain will be big enough?
Also, while STOCK, I had a -5% error on the Speedo (checked with a GPS). After the 16T was put on, it was about a -10% error. This is pretty much exactly what should happen according to the on-line calculators on the websites that sell the Speedo Healer and SpeedoDrd. Interestingly, after the 16T was put on, I had about the same speed indicated on my bike at 3000 and 3500 RPM as I did stock (47mph @ 3000 rpm and 53mph @ 3500 rpm although as mentioned above, the GPS numbers changed from 5% error to 10% error.
Lastly, my initial subjective feel with the 16T was not really noticeable from stock. I hope after driving it a bit more, I will notice it out in town. I also hope to notice the difference when going to the 47T in back. Sorry for being lengthy here but again my real only question now is will 130 links be a long enough chain? THank you!
I poked around the web and found that the 16/47 combo works with the stock chain as I originally suggested.
I'm not sure how you tried to put the chain back on once you had the 47T sprocket on there, but you may have to put it on w/o the axle in place so that the wheel can move forward enough. Then once the chain is in place just raise the wheel and bring it back so you can slide the axle through. Might be a good idea to have a second person help you during this step.
