2012 Mod List thread
Parts arriving...
Got these last night. ;) I was surprised that there was no spacer tube to cut, just a bunch of washers... so I talked to Race Tech and he says I lay the replacement spring next to the original spring. Whatever the difference between the two is, I either cut from the stock spacer (too long), or make up the difference by stacking shims (too short). So, I could be using as few as one shim (washers) per fork...or maybe as many as six where they gave me twelve in the one package.
The rest is on the way...
attachment.php
Turbo conversion?
My list :
Drop forks
Nitron shock
Gut the cat
55-profile rear tire
Maybe new double bubble screen
Maybe some bling red bits
Then I'll take it to the track and make it squirm
Sent from my mobile phone, please excuse the brevity
Just as Eric suggested, here is the 2012 Mod List thread :D
The work I have to do on the bike...
Fit the Akrapovic and Evotech hanger
Remove the exup system/or cables if I dont get an eliminator
Fit the Penske rear shock
Do the AIS removal
Fit the K&N filter
Do the air box mod
Clean up the bottom half of the stock headers
Reflash or PCV
Dyno run it
GiPro install
seat upgrade
Volt meter install
Re-adjust suspension for the Penske install
Fuel line mod if required
Maybe LEDs for indicator lights
Add:
R6 Master Cylinder upgrade
HEL SS brake lines
May have a go at building an exup eliminator circuit board...
A few more bits are in...
These arrived yesterday. :yes:
Custom front and rear brake lines for both the bikes. She got the Dark Purple with gold banjos and I got the Denim Blue translucent with blue banjos.
attachment.php
attachment.php
attachment.php
My mods are...
Micron slip-on
Jet Kit
R1 shift linkage
Seargent Seat
Ducati Hypermotard handguard/mirror
Oxford heated grips
Heads up voltage meter
Blue LED dash lights
LED turn and brake signals
Knight designs 1" lower foot pegs
Gold D.I.D. chain
Steel superlite sprockets
Framesavers
Genuine Yamaha Luggage rack
Accsessory relay and barrier strip
Marine 12 volt outlet
Headlight power saver switch
Updated list progress:
Eric's FZ1:
  • DONE Install new colored HEL front and rear brake lines
  • DONE Install Evotech Fender Eliminator kit
  • Rebuild GPR Steering Stabilizer (Gasket and fluid replacement)
  • DONE Replace fork SPRINGS & oil with 5 weight and 7.5 weight mix
  • DONE Install new Penske8983 rear shock
  • Powder coat saddle bag supports
  • Repair and reinstall the CD pods
  • Purchase and install Power Commander V
Michele's FZ1:
  • DONE Install new Top Saddlery seats
  • Fab and finish saddle bag supports
Updated (again) list progress:
Eric's FZ1:
  • DONE Purchase and install Power Commander V
  • DONE Purchase spare header and gut the cat
  • DONE Test maps and settle on the best choice
  • DONE Fix issue with SpeedoDRD
  • DONE Replace Penske reservoir clamps with new ones covered in heat-shrink tubing.
Michele's FZ1:
I think for Michele, I'm going to use dherr687's suggestion. ;) http://www.998cc.org/forum/gen-ii-mods/12497-soft-saddlebag-supports-rev.html
