firefly
I need to replace my stock springs with stiffer ones, probably racetech, do I need to remove the forks off the bike to replace the springs?
Thanks
Thanks
Thanks guys for all the great information & step by step vid clips, this is exactly what I need, will order parts. oil & service manual. I'll go with racetech springs unless someone suggests better ones.
one more question, what oil wt does the manual recommend? I know the level is 140mm from your video clip.
Thanks.
I believe that stock wt is 5w for all the FZ1s. I know it is for the Gen II but I'll let one of the Gen I owners (or former owners... ) confirm this.
Hey Eric, I hope you can make a video for your USD fork rebuild. I should do that too (and add the 7WT, I'm a ton and a half of fun).
