firefly
I need to replace my stock springs with stiffer ones, probably racetech, do I need to remove the forks off the bike to replace the springs?
Thanks
Thanks
Thanks guys for all the great information & step by step vid clips, this is exactly what I need, will order parts. oil & service manual. I'll go with racetech springs unless someone suggests better ones.
one more question, what oil wt does the manual recommend? I know the level is 140mm from your video clip.
Thanks.
I believe that stock wt is 5w for all the FZ1s. I know it is for the Gen II but I'll let one of the Gen I owners (or former owners...) confirm this.
Hey Eric, I hope you can make a video for your USD fork rebuild. I should do that too (and add the 7WT, I'm a ton and a half of fun).
Anyone have any updated link to this video?Thanks Eric! I'm always happy when one of the how-to vids help out another member. Here is the link to the "Fork Rebuild" thread. It's not hard at all and like Eric said, you may as well remove them to change the oil and seals. It makes no sense at all to just swap out your springs and leave what may be "old" fluid and "old" seals in place. You won't get the full benefit of the new springs if you do that. Trust me, the fork parts from Partshark are super inexpensive which makes just redoing the forks a "no brainer".
Just click here: http://www.998cc.org/forum/gen-i-how/10475-geni-fork-rebuild-how.html
Thankyou
there’s two parts to this 1. Link is part 1
