Okay, I have some pics! Now please bear in mind that this is surely a rough draft and the very first prototype so it is not pretty. It is however functional, which is what I need right now. The main support is fiberglass and will be replaced with solid aluminum rod like you see the camera hanging from. Mind you I have no specialized tools and the aluminum piece you see was actually wood at first and was replaced today at work.
So this is the unit I made. It is a primitive pendulum. The weight of the camera plus tension on the locking nuts against the washers.
This is the rear view of the unit. The camera will have to operate in "upside down" mode but thats okay with me.
Here is the camera on a "slant". As the bike leans it will always want to remain level, or so thats what I want to happen.
This is the pivot point my great buddy Sal fabbed up at work for me out of aluminum rod. The brass sleeve acts as a bushing and has tension set on it with the nylon lock nuts so that it won't be swinging back and forth unless the bike is leaned over.....I hope.
Here's a shot of it leaned over from the rear. I can't wait to test this out!
So aside from going to a full Gyro Unit with battery power, which I may like to try as well, please criticize. It will help to maybe see something I am not which may help to make it better.
