Hell, I'm impressed at the stock seat with that milage10/10/2020 153.000 kmView attachment 26723
Google Translates that as "what work did you do on the bike ???"che lavoro hai fatto sulla bici ???120.000 miglia sull'orologio questa mattina quando sono partito per il lavoro.
2003 FZ1 Maintenance Log | ||||||
Date | Mileage | Oil Changed | Oil Filter Changed | Other Work Done | Notes | Miles on Tire/Brakes |
07.13.2013 | 39000 | Purchased | ||||
08.16.2013 | 40693 | Mobil 1 4MT 10-40 | Fram ph6017a | |||
08.27.2013 | New Front Brake Pads | |||||
09.16.2013 | New Front Tire | Moved from 02 FZ1 | ||||
11.30.2013 | 44900 | New Rear Tire | Moved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)] | |||
03.11.2014 | 47752 | Added some Oil. | ||||
03.11.2014 | 47789 | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | ||||
05.03.2014 | 49640 | New Front Tire | ||||
06.24.2014 | 51471 | Mobil 1 4MT 10-40 | Fram ph6017a | |||
09.05-2014 | 53943 | New Rear Tire | Bridestone Sport Touring Battlax T30 180/55ZR17 | 9957 | ||
10.08.2014 | 55176 | Fork Seals and Bushing Replaced. | ||||
10.08.2014 | 55176 | New NGK Plugs | ||||
10.08.2014 | 55176 | Radiator Flush | Removed Radiator to get to spark plugs. Refilled. Peak | |||
11.02.2014 | 56567 | Mobil 1 4MT 10-40 | Fram ph6017a | Oil Changed. | ||
03.28.2015 | 61500 | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11860 | ||
03.28.2015 | 61500 | New Gasket Yamaha Part Number 3273697 | ||||
05.30.2015 | 63734 | Lucas semi syn 10-40 | Fram ph6017a | |||
06.12.2015 | 63900 | New Rear Tire | Bridgestone T30 180/55ZR17 | 8600 | ||
10.15.2015 | 67711 | New Rear Brake Pads | ||||
01.15.2016 | 70680 | Lucas semi syn 10-40 (3 quarts) | wix 51358 |
02.27.2016 | 72500 | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11000 | ||
02.27.2016 | 72500 | New Rear Tire | Bridgestone T30 180/55ZR17 | |||
06.07.2016 | 75680 | added 9oz oil | ||||
07.04.2016 | 75948 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | .5 Quart still in Bottle on shelf | ||
11.24.2016 | 81494 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | .5 Quart still in Bottle on shelf | ||
02.04.2017 | 83000 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 10500 | ||
2.27.2017 | 83450 | Valve Adjustment | 2 shims moved, one replaced. new Plugs, new air filter. | |||
04.15.2017 | 85594 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,094 | ||
04.21.2017 | 86000 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | |||
05.19.2017 | 87000 | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | ||||
07.03.2017 | 88000 | Lucas Semi Syn 10-40 | Added 1/3 quart | |||
08.01.2017 | 89750 | Lucas Semi Syn 10-40 | Added 1/3 quart | |||
10.09.2017 | 92400 | seat covered | SOS in oceanside. 1 year warranty. | |||
10.14.2017 | 92654 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9654 | ||
10.31.2017 | 93449 | Lucas Semi Syn 10-40 | Added 1/2 quart | |||
11.08.2017 | 93876 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | Oil Changed | ||
11.08.2017 | 93876 | New Battery | YUASA BATT YT14B-4 (YT14B-BS) - $119.00 | |||
02.23.2018 | 97xxx | Lucas Semi Syn 10-40 | Added 200ml | |||
03.31.2018 | 98180 | Lucas Semi Syn 10-40 (3.5 qts) | mobil1 m1-108 | |||
05.23.2018 | 99453 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,859 | ||
05.23.2018 | 99453 | New Front Brake Pads | Renthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ1 | 57,453 | ||
07.31.2018 | 102316 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9,662 | ||
08.17.2018 | 103120 | Lucas Semi Syn 10-40 (3.5 qts) | wix 51358 XP | |||
11.27.2018 | 105756 | added 200ml | ||||
02.24.2019 | 107407 | Mobil 1 10-40 Full Syn (3.5 qts | Fram ph6017a | |||
03.20.2019 | 107980 | new chain | RNK 530, work done at ECC - will need sprockets next time, get steel sprockets. | |||
05.27.2019 | 109831 | rear pads | EBC double h sintered | |||
06.13.2019 | 110772 | motorex 10/50 full syn 3.5 qts | mobil1 m1-108a | |||
08.08.2019 | 112000 | Fork Seals replaced - $200 Labor - $51.20 parts | ||||
10.19.2019 | 113661 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 11,345 | ||
10.19.2019 | 113,661 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 14,208 | ||
01.27.2020 | 115,140 | 3.5 qts Mobil 1 10/40 | Fram ph6017a | |||
03.21.2020 | 115,800 | motorex 10/50 full syn 3.5 qts | Filter kept | Water Pump Seals, New Impeller, new lower radiator bracket. | ||
08.22.2020 | 118,278 | motorex 10/50 full syn 3.5 qts | Mobil 1 M1-108a | |||
10.18.2020 | 119,500 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris) | 5,839 | ||
12.16.2020 | 120,600 | Rear Tail Light bulbs changed. |
