How many miles on your fz1??
That is great! Any issues beyond normal maintenance?
The water Pump Seal and Impeller needed to be replaced a while back - I had the shop do that. I fixed a seal in the thermostat housing myself and had 2 shims put into the motor around 66k when I heard a slight ticking sound. mostly just fluids and tires.
wow some impressive numbers here. I sold my '01 gen 1 last week with 69k on the odo. Bought a gen 2 to replace it that only had 6300mi on it and I'm happily commuting to work again.
Here is my personal Log I keep on the bike.
DateMileageOil ChangedOil Filter ChangedOther Work DoneNotesMiles on Tire/Brakes
07.13.201339000Purchased
08.16.201340693Mobil 1 4MT 10-40Fram ph6017a
08.27.2013New Front Brake Pads
09.16.2013New Front TireMoved from 02 FZ1
11.30.201344900New Rear TireMoved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)]
03.11.201447752Added some Oil.
03.11.201447789New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA
05.03.201449640New Front Tire
06.24.201451471Mobil 1 4MT 10-40Fram ph6017a
09.05-201453943New Rear TireBridestone Sport Touring Battlax T30 180/55ZR179957
10.08.201455176Fork Seals and Bushing Replaced.
10.08.201455176New NGK Plugs NGK "R" CR9E Use sparkplug tool in bike tool kit
10.08.201455176Radiator FlushRemoved Radiator to get to spark plugs. Refilled. Peak
11.02.201456567Mobil 1 4MT 10-40Fram ph6017aOil Changed.
03.28.201561500New Front TireBridgestone T30 120/70ZR 17M/C11860
03.28.201561500New Gasket Yamaha Part Number 3273697
05.30.201563734Lucas semi syn 10-40Fram ph6017a
06.12.201563900New Rear Tire Bridgestone T30 180/55ZR178600
10.15.201567711New Rear Brake Pads
01.15.201670680Lucas semi syn 10-40 (3 quarts)wix 51358
02.27.201672500New Front TireBridgestone T30 120/70ZR 17M/C11000
02.27.201672500New Rear TireBridgestone T30 180/55ZR17
06.07.201675680added 9oz oil
07.04.201675948Lucas semi syn 10-40 (3.5 quarts)wix 51358.5 Quart still in Bottle on shelf
11.24.201681494Lucas semi syn 10-40 (3.5 quarts)wix 51358.5 Quart still in Bottle on shelf
02.04.201783000New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven10500
2.27.201783450Valve Adjustment2 shims moved, one replaced. new Plugs, new air filter.
04.15.201785594New Front Tire120/70ZR-17 (58W) Shinko 009 Raven13,094
04.21.201786000Lucas semi syn 10-40 (3.5 quarts)wix 51358 XP
05.19.201787000New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA
07.03.201788000Lucas Semi Syn 10-40Added 1/3 quart
08.01.201789750Lucas Semi Syn 10-40Added 1/3 quart
10.09.201792400seat coveredSOS in oceanside. 1 year warranty.
10.14.201792654New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven9654
10.31.201793449Lucas Semi Syn 10-40Added 1/2 quart
11.08.201793876Lucas semi syn 10-40 (3.5 quarts)wix 51358 XPOil Changed
11.08.201793876New BatteryYUASA BATT YT14B-4 (YT14B-BS) - $119.00
02.23.201897xxxLucas Semi Syn 10-40Added 200ml
03.31.201898180Lucas Semi Syn 10-40 (3.5 qts)mobil1 m1-108
05.23.201899453New Front Tire120/70ZR-17 (58W) Shinko 009 Raven13,859
05.23.201899453New Front Brake PadsRenthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ157,453
07.31.2018102316New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven9,662
08.17.2018103120Lucas Semi Syn 10-40 (3.5 qts)wix 51358 XP
11.27.2018105756added 200ml
02.24.2019107407Mobil 1 10-40 Full Syn (3.5 qtsFram ph6017a
03.20.2019107980new chainRNK 530, work done at ECC - will need sprockets next time, get steel sprockets.
05.27.2019109831EBC double h sintered
06.13.2019110772motorex 10/50 full syn 3.5 qtsmobil1 m1-108a
08.08.2019112000Fork Seals replaced - $200 Labor - $51.20 parts
10.19.2019113661New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven11,345
10.19.2019113,661New Front Tire120/70ZR-17 (58W) Shinko 009 Raven14,208
01.27.2020115,1403.5 qts Mobil 1 10/40Fram ph6017a
03.21.2020115,800motorex 10/50 full syn 3.5 qtsFilter keptWater Pump Seals, New Impeller, new lower radiator bracket.
08.22.2020118,278motorex 10/50 full syn 3.5 qtsMobil 1 M1-108a
10.18.2020119,500New Rear Tire180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris)5,839
12.16.2020120,600Rear Tail Light bulbs changed.
01.17.2021120,714Thermostat Housing Gasket - Added Coolant
01.17.2021120,714New NGK Plugs NGK CR9EIX Iridium Use sparkplug tool in bike tool kit
04.19.2021121187motorexadded some oil
04.20.20211212583.5 quarts Lucas 10/40 semi synmobil 1 M1-108a
04.20.2021121258added brake fluid to rear reservoir
05.14.20221258913.5 quarts Lucas 10/40 semi synfram ph6017a
08.03.2022126652New Rear Tire180/55ZR-17 (73W) Michellin Road 4 - Shinko Blew Out on the Freeway7,152
05.29.20231292923.5 quarts lucas 10/40 semi synmobil 1 m1-108a
07.17.2023New Front TIre
10.08.201455176New NGK PlugsNGK "R" CR9E Use sparkplug tool in bike tool kit
06.12.201563900New Rear TireBridgestone T30 180/55ZR178600
01.17.2021120,714New NGK PlugsNGK CR9EIX Iridium Use sparkplug tool in bike tool kit
LOL I had to click on your profile cause I knew you had to drive year round. I'm somewhat jealous only getting maybe 6 months of driving. Very detailed. I'm lucky I put enough miles on to change the oil once a year. Cheers.
Until the last few years I did ride all winter - I also used to ride to work 5 days a week, but since Pandemic I am remote 2 days a week now. Once I got into my forties I grew tired of riding in the winter when it is dark and in the upper 30's or lower 40's in the morning. This past year I hardly rode at all during the winter since we had so much rain in SoCal, I prefer to be in my truck when it is wet outside.
Parking at work is going to be a nightmare during construction for at least a year, so I might be riding it all winter long just to not have to park offsite and ride a shuttle bus into campus.
that goes to show a plug change every 8k is a bit ridiculous.
how did that blow out on the highway go? How did the bike act And what was the cause? Have never had one but curious.
Lol this thread makes me feel somewhat less like a complete dork. I have a spreadsheet too, very similar to the one above. My 08 is approaching 50K, only 8K of which are mine.
Ok still probably a dork. :)
Not a dork dude. Been keeping a log since 2008. Haha. It helps!
