Huggers
Greetings to all
Started modin my 08 FZ1-S
Have fitted Remus exhaust and Givi panniers but would like to fit
colour matched hugger poss with extra brake light but don't want anything tacky
looking
can you give me your thoughts/experience
Addmore
Greetings to all
looking
If it's just lights that you want try the "Admore lighting" kit for the bags that you have. It was a relatively easy install and gives you tail, brake and signals. It is made in Calgary,Alberta, Canada. The kit cost me $160.00 Canadian. That would be about 90 lbs?
check out AdMore Lighting - About Us
Depending on your regulations over there you may not have to leave your existing signal lights on like I did.I am planning to put smaller LED replacments on when I find ones that I like.
I've just taken off my R&G hugger to see if I can repair it. Less than a year of use and it cracked not far from the left side bolt.
Aww mate that's not good to hear. Less than a year so I'd contact the company and ask them what they can do for you. I like the look of the R&G hugger and fancy one on my ride. Why do you think it failed, was the nuts done up too tight or could it be bad design ?
