Gohot229
Wizard
Here's a bit of a cross between HaleyMan's idea with the fishing weights and the "Bar Snake". While looking at HaileyMans idea something occured to me, it seems that alot of guys are turned off by the difficulty of yanking (pulling) the "Bar Snake" through the bars, and it's been described as difficult at best, pluss the cost. Well this ideas not far from the "Bar Snake"s idea. How about surgical rubber tubing.....take SRT and pull it through the bars, then slide/pull in the weights all lined up and on fishing line, mabe fly fishing line or 20+lb test monofilamint like a necklace into the rubber tubing after the tubings been pulled into the bars. The size of the surgical tubing 'JUST' barely an interferance fit of the inside diameter of the bars but not snug, then with the line through the tubing pull the weights into place, into the tubing. You'd surely have to use a lubricant for slippage, a soap of some kind, as vasaline or a like product being a 'Petroleum" jelly might deteriorate the surgical tubing, but a soap something would work and could be rinsed out through the bars. This would give you shock between the bar, surgical rubber and weights. Additionally it would not deteriorate the lead into dust over time.
