List your mods..
The list grew a bit over time. But this will be the 7th riding season on my FZ1. I've never kept a bike this long... And I can honestly say that there's still nothing that makes me go WOW and want to sell this to buy a new bike! The 2009 was lightly crashed, fixed and sold. All of this is now moved to a 2013 bought new in 2014.
DONE:
T-Rex Racing frame sliders
Two Brothers Titanium slip-on
Evotech Exhaust hanger
AIS removed
Top Saddlery seats
Airbox modded
K&N Air filter
SAE power lead fed to the fairing
Marine grade cigarette power outlet
GPR Steering stabilizer
OEM Lower cowl
Copperdawg Strike seat cowl
Copperdawg medium scalloped screen
FP levers
RAM mount with Aquabox
Faux CF tank protector
Faux CF Yamaha decals
PIAA Dual 500/600hz horns
JW Radiator Guard
Aluminum O-Ring Valve Stem Caps
EFI fuel line mod
Swingarm spools
Power Commander V
Ivan's Flash on the ECU
Waiting to install:
Racetech 1.0 kg Springs and 6w fork oil
Oxford heated grips
Euro Sport Scoops
Also have the set of four Copperdog blinker pods but I broke one front and one rear and need to figure out replacement or repairing. I have some ideas! ;)
Ok, let's have all your lists or update what you've posted. :D
The list grew a bit over time. But this will be the 4th riding season on my FZ1. I've never kept a bike this long... And I can honestly say that there's still nothing that makes me go WOW and want to sell this to buy a new bike!
DONE:
AIS removed
Top Saddlery seats
LED Pod running/signal amber lights
Airbox modded
K&N Air filter
Syntec Heated grip kit
OEM Lower cowl
Modified sub-throttle plates
Yamaha Euro Sport Scoops.
Fire Dragon Brothers levers
JW Radiator Guard
SpeedoDRD
New EFI fuel line
Shipped or here and waiting to install:
Penske 8983 Dual adjustable with remote reservoir
HEL Brake lines (front and rear)
Evotech Fender eliminator
All that and no PC3/5 yet? Good call on the suspension. Try 10w on the compression side and 5 wt on the rebound like Duke did. Confirm exactly which side is which....
Oh my contribution:
Penske 8983 Shock|08 R1 Forks,Calipers,MC|HyperPro Damper
HEL SS Lines (Trans Red)|ebay 3-way Adj Levers (black/red)|SM2 Bars|Giles Rearsets (black)
Micron Full System|Lars AB|BMC Filter|Roth Stacks,AIE|FCE|CD Flies|PC5|Arao EXUP Elim,Shelf|BS Fuel Line Mod|SHv4
CF Chin Cowl, PB CF Hugger
T-Rex Frame,Axle Sliders|Targa FE
RAD-Armor Radiator Guard (Gold)
Spencer Seat|Puig DB|TechSpec Tank Grips
Heated Grips|HIDs|Proton Flushmounts
Custom GPS mount|Givi V35s,Shad 25 seat mounted
Red CNC bits all over, fuel cap, oil cap
Tank stripes inverted on the rear tail pieces.
Whistler Cruisader Radar Detector in the fairing.
Marine power outlet|SAE connector under the seat
Parts waiting to go on:
Easton Bars
Backup Parts:
Complete 07 raven bodywork
ASV FZ1 Levers
FZ1 Front forks, calipers, rear shock
Smoke Headlight Lens
Stock Exhaust
Scorpion CF slip on (commute/tour)
Pics:
Mods
- Oggy Knobbs frame sliders
- Evotech FE
- Magical Racing Clear/CFRP screen
- Ventura seatbag
- Driven Axle Block Sliders
2B fitted in a few weeks time when i get home:
- Penske 8983,
- Akrapovic Slip-on & Evotech ex hanger,
- K&N airfilter,
- Motovation Fork Sliders,
- PSR AIS blockoff plates
Coming soon:
PC-V or maybe ECUnleashed remap
Brembo RCS19 or R1/R6 Radial Master Cylinder
HEL SS brake lines
seat upgrade....
Hmm...lets see if I can remember them all.
Akrapovic carbon hex Slip-on (shortened 80mm)
Arrow headers
Modded Airbox with DNA air filter
Copperdawg Flies
PCV with custom dyno tune
16T front Sprocket, 47T rear sprocket
2008 R1 front forks and 6 pot brakes
2007/08 R6 Master Cylinder
HEL steel braided brake lines
Penske 8983 rear shock
Rizoma conical bars
Rizoma 60mm risers
Progrip 723 Grips
Rhinomoto bar ends
ASV F3 levers
CRG Arrow bar end mirrors
Shogun frame sliders
Healtech X-type GIPro gear indicator
Healtech Speedo healer
Evotech Fender Eliminator
Evotech exhaust hanger
Yamaha Flyscreen
Yamaha LED indicators
Yamaha Lower cowl
Yamaha seat cowl
Dirtroad seat
Washer mod
Oberon footpegs
Cox radiator guard
Mods:
Lars air box mod
BMC air filter
Ivan's FCE
Copperdawg reduced flies
Power commander V
Graves velocity stacks
Graves full exhaust
Speedo healer V4
JT + 3 steel sprocket
RK 530 chain
Rizoma 42mm bar risers
Rizoma conical bars
Rizoma grips
Rizoma bar ends
CRG levers
Costom cut windscreen
Hightech speed proton front and rear flush turn signals
Smoked rear lens
Hid's (can't remember)
Dunlop q2 tires
Fender eliminator
Latest Update:
DONE:
Power Commander V with O2 eliminator
AIS removed
Top Saddlery seats
Airbox modded
K&N Air filter
FP adjustable levers
RAD Armor Radiator Guard
New EFI fuel line
Swingarm spools
Graves Velocity stacks
Ivan's ECU Flash
Copperdawg medium scalloped screen - Working on this prior to install
PIAA Dual 500/600hz horns (need to do HEL lines first to get the horn mount-points)
Marine grade cigarette power outlet (Drill and mount to left inner fairing panel)
OEM Lower cowl with Faux CF Yamaha decals - Needs work prior to install
RAM mount with Aquabox - Mount when Oxford panel is decided.
TO DO:
Oxford Heated grips - Install pending
Yamaha Euro Sport Scoops - Scotchbrite and re-spray
SpeedoDRD - Unsure if this will be used.
Racetech 1.0 kg Springs and 6w fork oil - Winter Project.
I can say that I am very happy with the FZ1 and the performance, especially after Ivan got done with my ECU. I crashed the 2009 on July 7th and bought a 2013 in the most awesome color of Cobalt Blue on 7/26/14 !! :tup: Above reflects the status of the 2013 as of 8/4/14. The CD blinker pods will not be replaced or re-used.
Mods:
Lars air box mod
BMC air filter
Ivan's FCE
Power commander V
Graves full exhaust
Speedo healer V4
RK 530 chain
Rizoma conical bars
Rizoma grips
Rizoma bar ends
CRG levers
Smoked rear lens
Dunlop q2 tires
Fender eliminator
What tire pressures do you run with the Q2's
Nitron Track shock - Hyperpro fork springs - Leo Vince SBK Factory Evo II Titanium slip-on - Servo Elim. - PC V w. Custommap - O2 Elim. - K&N air filter - Lars box mod - CD flies - Driven Block Off Plates - Motovation fork sliders - R&G frame sliders - RhinoMoto bar ends - CRG HS LS bar end mirrors - Pazzo shorty - Brembo 19RCS M/C - HEL SS brake lines - DPM oil cap - LighTech rear sets - Carbon hugger - clear led tail light- Kellermann Micro Rhombus led indictors - R&G FE - GSG exhaust hanger - Scottoiler - SpeedoHealer - Gel seat - Stompgrip
hi there
View attachment 14215mods are well what i can remember.pc3, k&n air filter, renthal bars, asv short levers, oxford heat grips,blackout head light protector,twin tailgunners exhaust,remove cat, 4 into 2 heddar pipes custom made,50 brake NOS kit, laser line alarm,custom exhaust hangers,bar ends,black flame mirrors,mini LED winkers,clear LED back light,fz1 rad grill, belly pan,seat cowl,side cowl wings, tail tidy,rear sets, braided lines,custom 3tone paint job,hyperpro steering damper,r&g crash protection bungs,headlight wind screen,16 tooth front sprocket.seat cowl and under seat cover are in spray shop at mo. and a wish list that id need a money tree to get:hook2::banghead:
Hi
Power bronze screen
Belly pan
Tail tidy
Small rear indicators
Small number plate
Pazzo levers
Hell brake lines all round
Rear hugger
Swing arm bobbins
190 rear tyer
Hyper pro damper
Akrapovic exhaust
Power commander 3
Ivan's map
Lars airbox mod
K&N filter
Secondary butterflies removed
Decat exhaust
Ais blocked off
I got a gen1 fz1
Ivans jet kit
K&n drop in filters
D&D show and go slip on with mid pipe (soon to be a yoshi)
Led intigrated tail light smoked
14t front and 44 rear
Flush mount led smokd front turn signals
Smoke wind screen
6k hid headlights
Shorty ajustable levers
I had a 2005 r1 and I give it to the fz1 hands down a better bike. .. for my needs
White FZ1N 2010
Mini carbon front & rear indicators
Tail tidy/fender eliminator
Oggy knobs frame sliders
Radguard radiator guard
K&N air filter
Scorpion slipon
Power Commander V
Ventura headlight protector
LED flasher unit
Custom rego plate
SDR black levers
Rear spools/bobbins
SpeedoDRD
Carbon tank pad
USB power point
90 degree valve stems
2007 Raven Black FZ1
Power Commander 5 with JonDaddy82 map
Yoshimura TRC Slip on
Vortex Rearsets
GPR Steering Damper
Lars air box mod
Graves Velocity Stacks
Scorpio Alarm System
Techspec Snakeskin Tank Grips
Cat gutted
Puig Racing Windscreen
Driven AIS block off plates
Heated grip
Fender Eliminator
Flush mount turn signals
Frame & axle sliders
Swingarm spools
Progrip Tank Pad
Progrip 719 Grips
Michelin Pilot Power 3 Tires
Bars turned down
2014 Yamaha FZ1
Engine Peformance:
- Mivv GP Black Slip-On
- BMC Air Filter
- LARS Air Box Mod
- AIS removal using Graves Block-Off Plates
- Graves Velocity Stacks
- Dynojet Power Commander 5
Protection:
- Woodcraft Engine Protectors (Oil Pump Cover & Ignition Cover)
- Woodcraft Frame Sliders
- Woodcraft Axle Slider (Front & Rear)
- Woodcraft Swing Arm Sliders
Suspension/Footwork:
- LighTech Rearsets
- OEM 2008 Yamaha R1 Shock using the Satan V4 Adapter
Lighting:
- Philips RacingVision H4 Bulbs
- Motodynamic Smoked LED Taillight
- Motodynamic Smoked DRL Flush Mount Turn Signals
Miscellaneous:
- CopperDawg SS2 Windscreen
- CopperDawg DV8R Belly Pan
- Skutrnet Servo Buddy (Servo Removed)
- Yoshimura Fender Eliminator
- TechSpec Snake Skin Tank Grips
- Ram Mount Handle Bar Mount with X-Grip IV Phone Holder
- MoDoor Garage Door Opener
Future Mods:
- 2007-2008 R1 forks w/6 Pot Brake Calipers
- Ivan's ECU Reflash
- Full System Yoshimura R77 w/Carbon Muffler
2014 Yamaha FZ1
Power Mods:
- Yoshimura R77 Slip-On
Bike Protection:
Lighting:
- Soon (Philips RacingVision H4 Bulbs)
Miscellaneous:
Future Mods:
- LighTech Rearsets
- Upgrade the Rear Shock (Not sure which route I'll be taking here...)
- 2007-2008 R1 w/6 Pot Brake Calipers
- ECU Reflash (possibly Ivan's) w/ PCV
- BMC Air Filter
- LARS Air Box Mod
- AIS removal
- Replace Flies w/CNC Flies (Ivan's or Coppedawg)
BTW If you do get Ivan's ECU flash then the modded flies are no longer needed as Ivans flash is designed to work with stock flies.
Sent from my Moto G (4)
