Oldschool
Had decent weather this Saturday, (warm enough to work in the garage) so I installed the MIVV. Had to remove the stock cannon first. Just a note regarding Copperdog's video; you don't have to cut the zip tie holding the servo lines. it is a reuseable type and came off easily without cutting. Otherwise his video instruction is right on the mark and made the job much easier.
removed the bottom servo cables.
Then the upper servo cables, and re-installed the motor unit.
Installed the mid pipe after polishing it.
Installed the can.
I did not yet start the bike. I showed uncharacteristic restraint in not starting it but I will film some video when I do. Here is a shot of the stock can off the bike with the db killer from the MIVV that I removed by drilling out the single stainless rivet.
I suggest to anyone removing the servo cables to make note of which one is top and bottom. The top cable at the servo unit is the bottom one at the pipe. You can see in the picture the cable adjuster on the bottom one is painted black, the other is plain stainless. I attached a peice of duct tape to the top cable at the servo and marked it for future reference.
For reference as well: (from Rusty's post) "I've just finished fitting the pipe and managed to put it on the scales....... Standard pipe was 7.2kg, Mivv weighed in at 3.3kg including the link pipe" This is a weight savings of 3.9 kg!
Installed the can.
