TPS Adjustment with Power Commander
Question? Has anyone ever gotten a true ZERO when doing the TPS calibration? Warm, cold, hot, mine always reads 0.664 to 0.669 and hitting reset doesn't change this. So, I did reset, pinned the throttle quickly and hit OK....
DynoJet Manual said:
TPS CALIBRATION
It is important that the PCV software TPS read 0% when the
bike is fully warmed up and at idle. If it needs to be reset
make sure the bike is fully warmed up before resetting. With
the engine running, click on Reset, quickly open throttle to
the wide-open throttle stop and quickly close, then click OK.
If your bike has fly-by-wire throttle only reset the throttle
position on a dynamometer while in gear and under load.
