Doogie2.0
Wow!! That's awesomeI've got 128,553 km on mine
Crossed the 130,000 mile mark on my Friday Commute last week.
The water Pump Seal and Impeller needed to be replaced a while back - I had the shop do that. I fixed a seal in the thermostat housing myself and had 2 shims put into the motor around 66k when I heard a slight ticking sound. mostly just fluids and tires.That is great! Any issues beyond normal maintenance?
Date | Mileage | Oil Changed | Oil Filter Changed | Other Work Done | Notes | Miles on Tire/Brakes |
07.13.2013 | 39000 | Purchased | ||||
08.16.2013 | 40693 | Mobil 1 4MT 10-40 | Fram ph6017a | |||
08.27.2013 | New Front Brake Pads | |||||
09.16.2013 | New Front Tire | Moved from 02 FZ1 | ||||
11.30.2013 | 44900 | New Rear Tire | Moved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)] | |||
03.11.2014 | 47752 | Added some Oil. | ||||
03.11.2014 | 47789 | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | ||||
05.03.2014 | 49640 | New Front Tire | ||||
06.24.2014 | 51471 | Mobil 1 4MT 10-40 | Fram ph6017a | |||
09.05-2014 | 53943 | New Rear Tire | Bridestone Sport Touring Battlax T30 180/55ZR17 | 9957 | ||
10.08.2014 | 55176 | Fork Seals and Bushing Replaced. | ||||
10.08.2014 | 55176 | New NGK Plugs | NGK "R" CR9E Use sparkplug tool in bike tool kit | |||
10.08.2014 | 55176 | Radiator Flush | Removed Radiator to get to spark plugs. Refilled. Peak | |||
11.02.2014 | 56567 | Mobil 1 4MT 10-40 | Fram ph6017a | Oil Changed. | ||
03.28.2015 | 61500 | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11860 | ||
03.28.2015 | 61500 | New Gasket Yamaha Part Number 3273697 | ||||
05.30.2015 | 63734 | Lucas semi syn 10-40 | Fram ph6017a | |||
06.12.2015 | 63900 | New Rear Tire | Bridgestone T30 180/55ZR17 | 8600 | ||
10.15.2015 | 67711 | New Rear Brake Pads | ||||
01.15.2016 | 70680 | Lucas semi syn 10-40 (3 quarts) | wix 51358 | |||
02.27.2016 | 72500 | New Front Tire | Bridgestone T30 120/70ZR 17M/C | 11000 | ||
02.27.2016 | 72500 | New Rear Tire | Bridgestone T30 180/55ZR17 | |||
06.07.2016 | 75680 | added 9oz oil | ||||
07.04.2016 | 75948 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | .5 Quart still in Bottle on shelf | ||
11.24.2016 | 81494 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 | .5 Quart still in Bottle on shelf | ||
02.04.2017 | 83000 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 10500 | ||
2.27.2017 | 83450 | Valve Adjustment | 2 shims moved, one replaced. new Plugs, new air filter. | |||
04.15.2017 | 85594 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,094 | ||
04.21.2017 | 86000 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | |||
05.19.2017 | 87000 | New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA | ||||
07.03.2017 | 88000 | Lucas Semi Syn 10-40 | Added 1/3 quart | |||
08.01.2017 | 89750 | Lucas Semi Syn 10-40 | Added 1/3 quart | |||
10.09.2017 | 92400 | seat covered | SOS in oceanside. 1 year warranty. | |||
10.14.2017 | 92654 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9654 | ||
10.31.2017 | 93449 | Lucas Semi Syn 10-40 | Added 1/2 quart | |||
11.08.2017 | 93876 | Lucas semi syn 10-40 (3.5 quarts) | wix 51358 XP | Oil Changed | ||
11.08.2017 | 93876 | New Battery | YUASA BATT YT14B-4 (YT14B-BS) - $119.00 | |||
02.23.2018 | 97xxx | Lucas Semi Syn 10-40 | Added 200ml | |||
03.31.2018 | 98180 | Lucas Semi Syn 10-40 (3.5 qts) | mobil1 m1-108 | |||
05.23.2018 | 99453 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 13,859 | ||
05.23.2018 | 99453 | New Front Brake Pads | Renthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ1 | 57,453 | ||
07.31.2018 | 102316 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 9,662 | ||
08.17.2018 | 103120 | Lucas Semi Syn 10-40 (3.5 qts) | wix 51358 XP | |||
11.27.2018 | 105756 | added 200ml | ||||
02.24.2019 | 107407 | Mobil 1 10-40 Full Syn (3.5 qts | Fram ph6017a | |||
03.20.2019 | 107980 | new chain | RNK 530, work done at ECC - will need sprockets next time, get steel sprockets. | |||
05.27.2019 | 109831 | EBC double h sintered | ||||
06.13.2019 | 110772 | motorex 10/50 full syn 3.5 qts | mobil1 m1-108a | |||
08.08.2019 | 112000 | Fork Seals replaced - $200 Labor - $51.20 parts | ||||
10.19.2019 | 113661 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven | 11,345 | ||
10.19.2019 | 113,661 | New Front Tire | 120/70ZR-17 (58W) Shinko 009 Raven | 14,208 | ||
01.27.2020 | 115,140 | 3.5 qts Mobil 1 10/40 | Fram ph6017a | |||
03.21.2020 | 115,800 | motorex 10/50 full syn 3.5 qts | Filter kept | Water Pump Seals, New Impeller, new lower radiator bracket. | ||
08.22.2020 | 118,278 | motorex 10/50 full syn 3.5 qts | Mobil 1 M1-108a | |||
10.18.2020 | 119,500 | New Rear Tire | 180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris) | 5,839 | ||
12.16.2020 | 120,600 | Rear Tail Light bulbs changed. | ||||
01.17.2021 | 120,714 | Thermostat Housing Gasket - Added Coolant | ||||
01.17.2021 | 120,714 | New NGK Plugs | NGK CR9EIX Iridium Use sparkplug tool in bike tool kit | |||
04.19.2021 | 121187 | motorex | added some oil | |||
04.20.2021 | 121258 | 3.5 quarts Lucas 10/40 semi syn | mobil 1 M1-108a | |||
04.20.2021 | 121258 | added brake fluid to rear reservoir | ||||
05.14.2022 | 125891 | 3.5 quarts Lucas 10/40 semi syn | fram ph6017a | |||
08.03.2022 | 126652 | New Rear Tire | 180/55ZR-17 (73W) Michellin Road 4 - Shinko Blew Out on the Freeway | 7,152 | ||
05.29.2023 | 129292 | 3.5 quarts lucas 10/40 semi syn | mobil 1 m1-108a | |||
07.17.2023 | New Front TIre |
LOL I had to click on your profile cause I knew you had to drive year round. I'm somewhat jealous only getting maybe 6 months of driving. Very detailed. I'm lucky I put enough miles on to change the oil once a year. Cheers.Here is my personal Log I keep on the bike.
Date Mileage Oil Changed Oil Filter Changed Other Work Done Notes Miles on Tire/Brakes 07.13.2013 39000 Purchased 08.16.2013 40693 Mobil 1 4MT 10-40 Fram ph6017a 08.27.2013 New Front Brake Pads 09.16.2013 New Front Tire Moved from 02 FZ1 11.30.2013 44900 New Rear Tire Moved from 02 FZ1 [Bridgestone Sport Touring Battlax BT023 180/55Z 17R M/C (73w)] 03.11.2014 47752 Added some Oil. 03.11.2014 47789 New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA 05.03.2014 49640 New Front Tire 06.24.2014 51471 Mobil 1 4MT 10-40 Fram ph6017a 09.05-2014 53943 New Rear Tire Bridestone Sport Touring Battlax T30 180/55ZR17 9957 10.08.2014 55176 Fork Seals and Bushing Replaced. 10.08.2014 55176 New NGK Plugs NGK "R" CR9E Use sparkplug tool in bike tool kit 10.08.2014 55176 Radiator Flush Removed Radiator to get to spark plugs. Refilled. Peak 11.02.2014 56567 Mobil 1 4MT 10-40 Fram ph6017a Oil Changed. 03.28.2015 61500 New Front Tire Bridgestone T30 120/70ZR 17M/C 11860 03.28.2015 61500 New Gasket Yamaha Part Number 3273697 05.30.2015 63734 Lucas semi syn 10-40 Fram ph6017a 06.12.2015 63900 New Rear Tire Bridgestone T30 180/55ZR17 8600 10.15.2015 67711 New Rear Brake Pads 01.15.2016 70680 Lucas semi syn 10-40 (3 quarts) wix 51358 02.27.2016 72500 New Front Tire Bridgestone T30 120/70ZR 17M/C 11000 02.27.2016 72500 New Rear Tire Bridgestone T30 180/55ZR17 06.07.2016 75680 added 9oz oil 07.04.2016 75948 Lucas semi syn 10-40 (3.5 quarts) wix 51358 .5 Quart still in Bottle on shelf 11.24.2016 81494 Lucas semi syn 10-40 (3.5 quarts) wix 51358 .5 Quart still in Bottle on shelf 02.04.2017 83000 New Rear Tire 180/55ZR-17 (73W) Shinko 009 Raven 10500 2.27.2017 83450 Valve Adjustment 2 shims moved, one replaced. new Plugs, new air filter. 04.15.2017 85594 New Front Tire 120/70ZR-17 (58W) Shinko 009 Raven 13,094 04.21.2017 86000 Lucas semi syn 10-40 (3.5 quarts) wix 51358 XP 05.19.2017 87000 New Chain Installed - NCHM RK Chain 530XSOZ1-120 XRING MA 07.03.2017 88000 Lucas Semi Syn 10-40 Added 1/3 quart 08.01.2017 89750 Lucas Semi Syn 10-40 Added 1/3 quart 10.09.2017 92400 seat covered SOS in oceanside. 1 year warranty. 10.14.2017 92654 New Rear Tire 180/55ZR-17 (73W) Shinko 009 Raven 9654 10.31.2017 93449 Lucas Semi Syn 10-40 Added 1/2 quart 11.08.2017 93876 Lucas semi syn 10-40 (3.5 quarts) wix 51358 XP Oil Changed 11.08.2017 93876 New Battery YUASA BATT YT14B-4 (YT14B-BS) - $119.00 02.23.2018 97xxx Lucas Semi Syn 10-40 Added 200ml 03.31.2018 98180 Lucas Semi Syn 10-40 (3.5 qts) mobil1 m1-108 05.23.2018 99453 New Front Tire 120/70ZR-17 (58W) Shinko 009 Raven 13,859 05.23.2018 99453 New Front Brake Pads Renthal RC-1 Sport Brake Pad - Sintered Double H - Front Left - 2003 YAMAHA FZ1 57,453 07.31.2018 102316 New Rear Tire 180/55ZR-17 (73W) Shinko 009 Raven 9,662 08.17.2018 103120 Lucas Semi Syn 10-40 (3.5 qts) wix 51358 XP 11.27.2018 105756 added 200ml 02.24.2019 107407 Mobil 1 10-40 Full Syn (3.5 qts Fram ph6017a 03.20.2019 107980 new chain RNK 530, work done at ECC - will need sprockets next time, get steel sprockets. 05.27.2019 109831 EBC double h sintered 06.13.2019 110772 motorex 10/50 full syn 3.5 qts mobil1 m1-108a 08.08.2019 112000 Fork Seals replaced - $200 Labor - $51.20 parts 10.19.2019 113661 New Rear Tire 180/55ZR-17 (73W) Shinko 009 Raven 11,345 10.19.2019 113,661 New Front Tire 120/70ZR-17 (58W) Shinko 009 Raven 14,208 01.27.2020 115,140 3.5 qts Mobil 1 10/40 Fram ph6017a 03.21.2020 115,800 motorex 10/50 full syn 3.5 qts Filter kept Water Pump Seals, New Impeller, new lower radiator bracket. 08.22.2020 118,278 motorex 10/50 full syn 3.5 qts Mobil 1 M1-108a 10.18.2020 119,500 New Rear Tire 180/55ZR-17 (73W) Shinko 009 Raven (replaced early due to split from road debris) 5,839 12.16.2020 120,600 Rear Tail Light bulbs changed. 01.17.2021 120,714 Thermostat Housing Gasket - Added Coolant 01.17.2021 120,714 New NGK Plugs NGK CR9EIX Iridium Use sparkplug tool in bike tool kit 04.19.2021 121187 motorex added some oil 04.20.2021 121258 3.5 quarts Lucas 10/40 semi syn mobil 1 M1-108a 04.20.2021 121258 added brake fluid to rear reservoir 05.14.2022 125891 3.5 quarts Lucas 10/40 semi syn fram ph6017a 08.03.2022 126652 New Rear Tire 180/55ZR-17 (73W) Michellin Road 4 - Shinko Blew Out on the Freeway 7,152 05.29.2023 129292 3.5 quarts lucas 10/40 semi syn mobil 1 m1-108a 07.17.2023 New Front TIre
Until the last few years I did ride all winter - I also used to ride to work 5 days a week, but since Pandemic I am remote 2 days a week now. Once I got into my forties I grew tired of riding in the winter when it is dark and in the upper 30's or lower 40's in the morning. This past year I hardly rode at all during the winter since we had so much rain in SoCal, I prefer to be in my truck when it is wet outside.LOL I had to click on your profile cause I knew you had to drive year round. I'm somewhat jealous only getting maybe 6 months of driving. Very detailed. I'm lucky I put enough miles on to change the oil once a year. Cheers.
Not a dork dude. Been keeping a log since 2008. Haha. It helps!Lol this thread makes me feel somewhat less like a complete dork. I have a spreadsheet too, very similar to the one above. My 08 is approaching 50K, only 8K of which are mine.
Ok still probably a dork.
That’s awesome! I can only hope the kids take my good traits.Same here!
Best part (for me) is that I taught my two girls to do the same and they have continued to do so since leaving the home!
