pantsman
This is the fender eliminator I made this weekend. It's just a piece of angle aluminum cut and bent into shape. I'm happy with the way it turned out, particularly for the cost of paint and a couple nuts and bolts (angle aluminum was free). The only damage I caused to stock parts was cutting the turn signal wires to be able to remove them from the stock fender. Anyhow, on to pictures!
These are when I was mocking it up before final assembly and painting but it basically looks the same except I didn't use the reflectors.
The only remaining thing, which I guess takes it over $10, is the plate bolts with LED's in them since there's no room above the plate.
So what do you think?
