PapaGeno21
Wizard
Well I got it August 30th 2010, and I just rolled over 4200. I figure by the end of this season, I will be in the 15K ballpark. Got a lot of trips planned, and will be doing a LOT of riding this season.
Looking good PapaG.
Did you leave the front end stock height or did you lower it again?
I put the R1 forks flush with the triple trees.. So that lowers it. The R1 forks are 16mm shorter than stock.
For me that will be too twitchy as I felt the bike was perfect when I had the stock forks raised 8mm up into the triples. So the way I ordered the Penske at full extension it will be stock length, but then I have a half inch to play around with making it shorter. So that will bring the ass end down a little bit so the front drop is not so drastic.
Wow, 16mm is a lot shorter.
I think you might find the Penske shock is still slightly longer than the FZ1 stock shock by a few mm, even at it's lowest setting.
Hopefully it won't be too twitchy for you, it should turn on a dime though.
Exactly why me and Lee set it up so when I get the shock it is 1/2" shorter than normal. At full extension it will be the same length as the stock shock, however I will be able to adjust the shock to be 12mm shorter than stock. You can order them however you want, so this we felt was best. I was afraid it would be too twitchy, so that is a perfect backup. Now I am currently not sure how I feel, I think I am going to have it just a couple mm's shorter than stock, as it is very twitchy right now but not to the point that its a bad thing, I just don't know if I am fully comfortable with it yet. Stock is 320mm eye to eye, he is sending it to me at 317 eye to eye. I should be able to go from 322 to 310 eye to eye for an adjustment range.
