I always keep staring at those fluid covers on ebay and have gone back and forth a 100 times on whether that bling is worth it.
I may pull the trigger. Ever wondered those foldable R1 levers fit out bikes? Also you should have grabbed those frame plugs since they r so cheap now. I actually put hole plugs from HD on mine which actually fit flush and better than those d2moto ones. But the cubby hole covers didn't work so well for the swingarm pivot.
Also your brake reservoir cover is upside down.
Actually I should have said foldable shifter and brake pedals.
And where are the powdercoated rearsets?
