Hellgate
Beautiful brake lines; really sharp looking, well thought out and wonderfully detailed. The fit is a little odd however. First I'd like to see the rear line about 1 to 1.5 inches longer. At the current length it is a doable, but very tight fit.
The front was a little odd fitting too. There is a left and right line and it is critical to get them on in the correct sequence. Left on first and right second. The right hand side is about 2 inches shorter. Now here's the odd fitting part, the banjo bolts have some pretty radical bends to them and honestly I'm a little stumped as to why. The left side is a good fit, the right makes a tight loop. See photo. I had other SS kits before and they have more of a traditional bend to them.
Bleeding was snap with the Mity Vac. I used Teflon tape to get a better seal on the zerks and eliminate any air bleed back. While I was doing this I replaced the zerks and flushed the entire brake fluid. Note the oxidation on the zerk. All three were like this. If you've got an older bike flush your fluid and check your zerks.
Performance wise the new lines are great! They have a nice firm feel and don't mush out during a hard pull. Nice! :shoot:
View attachment 2882View attachment 2883View attachment 2884View attachment 2885
