terdog
Disconnect the PC and see if it is the problem.
Im betting not.
Im betting not.
more than what used r1 coils are
Ive had my R1 coils for over 15K miles. They work fine.
Disconnect the PC for a day or 2. How often would you say that you get the sputter? Do that time frame plus a day or 2.
He ended up ordering and installing a new AIT sensor and his problem went away.Seems I have resolved the issue and it is one of two things. I have tested and passed the Intake Air Temperature Sensor and cleared the ECU from the error codes. And, as Phil had suggested, removed the SpeedoDRD. I just got back from about 15 miles of low speed cruising (35 to 45) keeping a steady throttle in the 3 - 4k RPM range. The bike did not sputter, surge, lurch, or falter in any way. So, it was one of these two items for sure.
