Team Yamaha Fz1
So this might have been going on for a while since on the highway at high speeds it would fall on her face?? Omg
I hope it’s not too late
So this might have been going on for a while since on the highway at high speeds it would fall on her face?? OmgI hope it’s not too late
The murky looking oil is a very bad sign. Hopefully the motor is ok. I would take it to the shop by trailer if possible. Like Doc says the Seafoam is definitely not the problem.
No the OIL is NOT murky it’s the Coolant that looks like clay water! The oil is still good!!!
Ah, I did not read carefully enoughOil is likely getting into the coolant. If that's the case it's surprising there isn't coolant also getting into the oil.
That would be the only way my coolant looks like CLAY WATER? That’s not as bad as coolant in the oil?
I’ve called the shop all day while at work and no one picked up. I’ll try again tomorrow or I’ll find another shop!
Im borderline scared now![]()
You might have a leaking head gasket if the coolant in the radiator is milky....
The weephole issue as mentioned means the seals on the water pump need to be replaced.
Well it shut off on me 6 times on the way home. The oil is still clean from what I can see but it FALLS FLAT ON HER FACE every 5 -7 mins and I have to let it sit and start then another 5-7 mins. I’m not going to ride it anymore until I take her to the shop!
You guys on this site are Awesome really I appreciate the responses.
I will Update once it’s in the shop and what is found.
That particular problem sounds like it could be an intermittent/failing fuel pump. Let us know what they find!
Ok I will be dropping the bike off tomorrow after work. Gave me an estimate of $300 to fix the leak and coolant flush.
We will see..![]()
Wow, I hope that's all it costs you! I'm looking at a little more than double that...
That is surprisingly reasonable! Hope it all works out well!
Ok here’s the update:
1. Water Pump seals are leaking
2. Coolant line that goes around the back of the engine is leaking
3. Oil pan has a leak somewhere
4. Getting everything done along with a oil change and coolant flush.
Total cost $410.00
Will have her back by Tuesday
One more update When I go pick her up and open her up!!
Dang man, that's a great price for all that! Hold onto that mechanic for dear life (assuming he does a good job)!
