Klurejr
Wizard
Take that bike back to the shop and make em fix whatever is leaking for free....
Needless to say I am Not in the best of moods!!! That along with one cyclinder that is not working this bike might just be done.. Just spent $900+ OMG
Yeah, looks like they applied it with 2" paint brush. People... I really don't understand them some... er, most times...
A little over a year ago, my youngest daughter and I drove to a suburb outside Philly (about a 4 hour trip) to buy a beautiful Triumph Speed Triple at a great price. Guy was very friendly, had service records, extra oil, service manual, etc. Took the bike for a test ride and right towards the end, it started a very light clattering. I figured it was cam chain tensioner related and I could fix that no problem. Get the bike home and go for another short ride. Sounded good on start up and the first couple of miles. As I got closer to home, it started CLANKING like I couldn't believe and I almost threw up, knowing I'd just bought a POS. Sure enough, took it to my mechanic and he was like "Man, I've NEVER seen an engine looking like this!" Took a pic of the oil pan and the bottom was a literal sludge of metal shavings and hunks of RTV sealant. He did a little investigative work with the shop where a couple of the service records were from and I realized the seller straight up lied about most of my questions. It was very hard/expensive lesson and I got VERY lucky on two counts: First, I got in touch with the seller and he was willing to refund half the money, and second, I found a buyer who happened to have a Speed engine in need of a chassis, so I recovered the cost of the bike. Had to pay the mechanic $600 for his work, so that sucked, but much less than it could've...
Sh!t. Sorry, man. I'd have some serious questions for the mechanic!
So it’s Dead????
I'm not a skilled "distance" mechanic, but it sure sounds that way, short of an engine rebuild...
DAMN IT
I changed the oil and started it up. Wasn’t leaking after I let it idle for about 12 mins. Took it around my neighborhood got to the front it starts to die out. Started leaking a little TOUCHED the oil and it had a HEAVY GAS SMELL. Opened my oil cap and sure enough smells like gas.
IS IT DEAD ☠
I know the 2 weeks is problematic but I would take it back until it's fixed. I was very doubtful that the running problems were due to the water pump or oil leak however...
Check the compression to determine if there is a problem with the rings. It may be that you have a stuck float in one or more of the carbs. This is a Gen 1 right?
A problem with the carbs could easily explain the poor running.
Yes Gen 1 however I just recently got jet kits installed and carbs synched
Also how do I check the compression
