jared p
Wizard
a power commander is exactly what you need to get better fuel economy out of your bike. having the fueling proper results in more power, meaning it takes less power to get to the same speeds, meaning less fuel is actually used, even if on the fueling map, fuel is added. since it's being use efficiently, you end up gaining mpg, not losing it. the trick is, you gotta get a power commander, it has the highest tuning resolution, and you have to have it dyno tuned with a custom fuel map made for your bike.
