johnnyontherocks
The Cosmic Avenger
I am pretty sure you can use the front fender in either direction ( FZ to R1 or R1 to FZ) up to current model years
Pete are you going to change the oil before installing?
Yes. I need to look up the weight, I think it's 5.
Lee recommended 7 wt, it's what I'am currently running
Started the install today. The axle arrived today, calipers are due tomorrow.
Before
Pete, are you going to use the stock rotors? Do you have to shim the calipers at all? Hope all goes well!
Shimming is only needed for 07-current R1 calipers.
