a badly adjusted carburetor, can send too much gas into the carburetor. And, the overflow will eventually, wash down the cylinder walls and into your oil pan. This also tends to foul the
spark plugs. Thus, one way to check for this problem is, to pull one of plugs and look for blackening on it. It could have a washed look as well. Cars that are more than ten years old, usually have mechanical fuel pumps.
So, is your vehicle’s engine is running with, a stuttering or knocking sound. Then, it is possible that, one cylinder is not firing correctly. Consequently, leading to gas condensing in the faulty cylinder and draining into your oil pan. Accurately diagnosing this problem, requires some specialized testing equipment and needs to be done by a trained mechanic.
Driving with a
blown head gasket, can easily ruin the engine, leading to costly repairs. You can run a compression test on your engine. Then, if there is a leak in the head gasket, the compression will be lower than expected.
So, The First Things To Check Are:
- Mechanical fuel pumps.
- Spark plugs.
- Badly adjusted carburetor (Gas could also leak into your intake manifold, if there is a carburetor problem).
- Low compression.
- Blown head gasket.
